[Qgis-user] Fwd: Trouble when adding a map from a wms using QGIS 3.4
Christian Yrrman
yrrman at gmail.com
Sun Mar 3 08:58:59 PST 2019
---------- Forwarded message ---------
Date: Sun, Mar 3, 2019 at 5:53 PM
Subject: Re: [Qgis-user] Trouble when adding a map from a wms using QGIS 3.4
To: Andrea Peri <aperi2007 at gmail.com>
HI Andrea,
works fine also here on QGIS3.6. Eventually you could use fiddler or
another python based local web proxy to intercept the network traffic. I'm
not aware of a more detailled log for WMS nor a plugin for intercepting in
QGIS directly - does anyone know?
Greetings
Chris
On Sun, Mar 3, 2019 at 5:26 PM Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> When I try to add a wms map
> from the url:
> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsambamm
> With parameters:
> epsg:3003, img/png
> I have an error:
> Layer not valid: Raster layer data source not valid (sorgente dati: wms,
> URI:
> contextualWMSLegend=0&crs=EPSG:3003&dpiMode=7&featureCount=10&format=image/png&layers=rt_ambamm.idcomuni.rt.poly&styles&url=
> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map%3Dwmsambamm
> But when add from the same wms server using the QGIS 2.18.18 with the same
> parameters it is added without any trouble.
> Is available a more detailed log in QGIS 3.4 to understand why it refuse
> to add my wms map ?
> Thx.
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190303/b9524b96/attachment.html>
