[Qgis-user] QGIS and Libre\OpenOffice
Tyler Veinot tylerkveinot at gmail.com
Mon Mar 4 06:38:34 PST 2019
Base is a front end but it can also be built with a embedded database of
either Firebird or HyperSQL and is becomes a xyz.odb file. What I want to
do is through QGIS open that xyz.odb file and get a view of all the tables,
much like when opening a filegeodatabase, and add the tables I want to my
map. When I use external databases like Postgres and Sqlite with the
LibreOffice front end I lose certain capabilities.
Firebird is a somewhat new feature and I have been experimenting with
Firebird embedded databases and external firebird databases and LibreBase.
When I last left it I had LibreBase interacting with a Firebird database
file and was trying to get QGIS to connect to that file using ODBC. The
Firebird database file works better than using Sqlite because I do not lose
some of the capabilities and features in LibreBase.
Maybe integrate was the wrong word but basically I want to setup a database
app in LibreBase and have the information displayed in QGIS without the use
of a import/export function.
Tyler
On Mon, Mar 4, 2019 at 10:01 AM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Hi Tyles,
> what exactly do you want to integrate? Currently QGIS can load LO
> spreadsheets, and build sophisticated form to insert data. As far as I
> can tell, Base acts as a front end to this and other database backends,
> much in the same way as QGIS does. Please let us know your user case,
> I'm sure we can find a positive solution.
> Thanks.
> On 04/03/19 14:39, Tyler Veinot wrote:
> > Has anyone done any work or know of some initial work regarding the
> > integration of OpenOffice/Libre Office and QGIS? I am looking for some
> > way to add LibreBase tables into QGIS to get something similar to how
> > Esri and Access can work together.
> > Thanks;
> > Tyler
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Paolo Cavallini - www.faunalia.eu
> QGIS.ORG Chair:
> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190304/9f44f6b8/attachment.html>
