[Qgis-user] QGIS package broken on Ubuntu Bionic with UbuntuGIS PPA
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Mar 5 02:27:54 PST 2019
Hi César,
this is the lesson I had to learn hard a dozend of times over the years:
Do not update any ububuntugis related packages "after" a QGIS version
update.
Those two parts of the eco-system never managed to get in sync, and
maybe never will (no idea how and why and what, I'm just a user).
On Linux Mint, I recently discovered in the Update manager the
possibility to right-click on a package name, and set it to be ignored
for updates.
And fortunately, a hover-over the package name reveals the source, so I
can deactivate all ubuntugis packages for updates within seconds.
Hope this helps ... next time
Cheers,
Bernd
Am 04.03.19 um 23:39 schrieb César Augusto Ramírez Franco:
> Hello,
> I don't know if this is the right place to ask this, so apologies if
> it isn't.
> Today I updated my system through apt and the gdal package got
> upgraded to 2.4.0 and at the same time the qgis package got removed.
> I'm using the ubuntugis-unstable PPA and the QGIS repo for ubuntugis:
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
> bionic main # ubuntugis
> deb https://qgis.org/ubuntugis bionic main # QGIS
> When I try to install QGIS again, apt complains of unmet dependencies:
> # apt install qgis
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> qgis : Depends: gdal-abi-2-3-0 but it is not installable
> Depends: libqgis-analysis3.6.0 but it is not going to be installed
> Depends: libqgis-app3.6.0 but it is not going to be installed
> Depends: python-qgis (= 1:3.6.0+28bionic-ubuntugis) but it is
> Recommends: qgis-plugin-grass but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> I read online that removing ubuntugis and installig from the ubuntu
> repo would solve the problem but I'm relying on some ubuntugis package
> versions, so what's the recommended solution? Shouldn't QGIS 3.6 be
> able to run with GDAL 2.4.0?
> Thanks in advance
> *César Augusto Ramírez Franco*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190305/60bca101/attachment.html>
