[Qgis-user] Qgis 3.6 problem
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Wed Mar  6 06:14:30 PST 2019
This is 99 % a bad CRS problem or a layer that has the right CRS but is badly georeferenced. Open a background layer with a WMS or from a satellite image from a plugin like OpenLayer.  This layer should be in the right place.  Then open each layer and click zoom to layer extent (right click on the layer in the layer panel).  You will find the layer that is not correctly georeferenced or that has an incorrect CRS.
Phil is correct when saying that in 3x, on the fly default. You may want to select « ask  what to do » if a CRS is not specified in the layer.  Your choice my be «  use the project or use the default CRS ».  That may throw things off.
Nicolas
> Le 6 mars 2019 à 07:08, Jukka <Jukka at olantera.fi> a écrit :
> Hi,
> It didn't help. I checked layers CRS in both versions. I am confused, because I have mene other projects and all are working perfect.
> -Jukka
> Lähettäjä: Phil Wyatt [phil at wyatt-family.com]
> Lähetetty: 6. maaliskuuta 2019 10:47
> Vastaanottaja: Jukka
> Kopio: qgis-user at lists.osgeo.org
> Aihe: Re: [Qgis-user] Qgis 3.6 problem
> Check the CRS and set it to the raster data and see how you go. I think V3 does on the fly projections all the time. In 2.18 you need to set that under settings, options, CRS.
> Cheers - Phil,
> On the road with his iPad
> On 6 Mar 2019, at 6:08 pm, Jukka <Jukka at olantera.fi> wrote:
>> Hi,
>> I have two version of Qgis, 3,6 and 2.18. In  both version I have problems. I started a new project and if I add raster layer map and vector layer on map, I only can see the map or vector layer, not both. But I have older projects that works allright. What is the problem?
>> -Jukka Olanterä
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190306/e9fc7248/attachment.html>
