[Qgis-user] Couldn't load plugin - QGIS 3.6 on Mac 10.14.3
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Sat Mar 9 22:33:37 PST 2019
You can try this one-click installer:
https://lutraconsulting.github.io/qgis-mac-packager/
Regards
Saber
On Sat, 9 Mar 2019, 18:56 kspencer, <karl.c.spencer at gmail.com> wrote:
> Hello folks,
> I'm a QGIS newb trying to install QGIS on my Mac. Any help would be
> greatly
> appreciated. Got this error when trying to run QGIS for the first time:
> Couldn't load plugin 'processing'
> ImportError:
> dlopen(/Library/Frameworks/SQLite3.framework/Versions/E/Python/3.6/sqlite3/_
> sqlite3.cpython-36m-darwin.so,
> 2): Library not loaded:
> /Library/Frameworks/SQLite3.framework/Versions/D/SQLite3 Referenced from:
> Reason: image not found
> Traceback (most recent call last):
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> line 309, in loadPlugin
> __import__(packageName)
> File
> line 672, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py",
> line 29, in
> from processing.tools.general import * # NOQA
> File
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/plugins/processing/tools/general.py",
> line 39, in
> from processing.core.Processing import Processing
> File
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
> line 58, in
> from processing.algs.qgis.QgisAlgorithmProvider import
> QgisAlgorithmProvider # NOQA
> File
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/plugins/processing/algs/qgis/QgisAlgorithmProvider.py",
> line 83, in
> from .ImportIntoSpatialite import ImportIntoSpatialite
> File
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/plugins/processing/algs/qgis/ImportIntoSpatialite.py",
> line 42, in
> from processing.tools import spatialite
> File
> File
> "/Applications/QGIS3.6.app/Contents/MacOS/../Resources/python/plugins/processing/tools/spatialite.py",
> line 29, in
> import sqlite3 as sqlite
> File
> File
> "/Library/Frameworks/SQLite3.framework/Versions/E/Python/3.6/sqlite3/__init__.py",
> line 23, in
> from sqlite3.dbapi2 import *
> File
> File
> "/Library/Frameworks/SQLite3.framework/Versions/E/Python/3.6/sqlite3/dbapi2.py",
> line 27, in
> from sqlite3._sqlite3 import *
> File
> ImportError:
> Referenced from:
> Python version: 3.6.7 (v3.6.7:6ec5cf24b7, Oct 20 2018, 03:02:14) [GCC 4.2.1
> Compatible Apple LLVM 6.0 (clang-600.0.57)]
> QGIS version: 3.6.0-Noosa Noosa, exported
> Python Path:
> /Users/karl/Library/Application Support/QGIS/QGIS3/profiles/default/python
> Support/QGIS/QGIS3/profiles/default/python/plugins
> /Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190310/86f7af98/attachment.html>
