[Qgis-user] Python Scripts (Boolean) in QGIS 3
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Tue Mar 12 06:05:15 PDT 2019
Hi Herbert,
with processing scripts ist has defintitly changed a lot. The thing is,
that in QGIS 2.18 it was python but mixed with some none python, like
the parameter with the double pound sign...like ##my_parameter=boolean
so a good starting point is the blog from Anita Graser, since the
documetation on qgis.org isn't that actual at the moment:
https://anitagraser.com/2018/03/25/processing-script-template-for-qgis3/
you can also start with the template directly in QGIS selecting "New
script from template.." in the processing toolbox top, where the python
icon is...
Hope this helps a bit
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSS Academy Kompaktkurs "Winterschule 2019"
Grundwissen zum Aufbau von Geodateninfrastrukturen mit
Open-Source-Software
https://foss-academy.com/kompaktkurse
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 2019-03-12 13:48, schrieb Herbert Lincon:
> Hello everyone,
> I have a script in QGIS 2.18 to receive the information from 4
> boolean options as simple as that
> ##formula_1=boolean
> ##formula_2=boolean
> ##formula_3=boolean
> ##formula_4=boolean
> ##result=output string
> if formula_1 == True:
> result= 1
> elif formula_2 == True:
> result= 2
> elif formula_3 == True:
> result= 3
> elif formula_4 == True:
> result= 4
> else:
> result= 5
> the problem is, this type of script doesn´t work in QGIS 3, and I´m
> a newbie in Python,
> could someone translate that to the new method?
> it´ll help me even begin to understand python 3
> Thanks
> Herbert Lincon
> Qgis-user mailing list
