[Qgis-user] QGIS error & F29
Max Pyziur
pyz at brama.com
Tue Mar 12 06:54:56 PDT 2019
On Tue, 12 Mar 2019, Richard Duivenvoorde wrote:
> Ah...
> Now I see 2.7 ????
> That is very old, please upgrade to the one available via
> https://qgis.org/en/site/forusers/alldownloads.html#fedora
Much thanks for your replies.
I've done this, but this has led to another issue. Either it's a bug or
I'm not executing something correctly (clicking checkboxes etc.
If I go Database -> DB Manager
Establish a connection to my postgresql/postgis database
F2 to open the SQL editing window, type:
SELECT * FROM "shapefiles"."us_states" WHERE state = 'Texas'
Hit Execute, Load As layer
Nothing appears in either the Layers pane or the main window.
However, if I go
Layer -> Add Layer -> Add PostGIS Layers
and then select a table built upon a shapefile
the map loads.
I can then edit the SQL for that layer by right-clicking on the layer in
the layer pane, Update sql, and my modifications are reflected in the
layer.
How do I get DB Manager to add a layer?
Much thanks,
Max Pyziur
> Regards,
> On 12/03/2019 07.08, Richard Duivenvoorde wrote:
>> Hi Max,
>> The error means that the python-cpp bridge is not working because wrong
>> paths to (python) libs.
>> Are you maybe in a Python Virtual Environment at that moment, which in
>> that case screws up your python path?
>> Or else: did you miss some QGIS-Python package (if installed via package
>> manager)?
>> Regards,
>> On 11/03/2019 23.15, Max Pyziur wrote:
>>> Greetings,
>>> My use of QGis Desktop is occassional; when I do use it, I construct
>>> layers using PostGIS & PostgreSQL.
>>> The key component that facilitates this in QGis is a Python plugin
>>> called DB Manager.
>>> When I started Qgis today, there was an error message that appeared
>>> something like this:
>>> Couldn't load PyQGIS. Python support will be disabled.
>>> Traceback (most recent call last):
>>> File "", line 1, in
>>> File "/usr/lib64/python2.7/site-packages/qgis/gui/__init__.py", line
>>> 27, in
>>> from qgis._gui import *
>>> RuntimeError: the PyQt4.QtCore module failed to register with the sip
>>> module
>>> Python version:
>>> 2.7.15 (default, Oct 15 2018, 15:26:09)
>>> [GCC 8.2.1 20180801 (Red Hat 8.2.1-2)]
>>> QGIS version:
>>> 2.18.20 'Las Palmas', exported
>>> After clicking away the error away, the existing layers that I had built
>>> using PostGIS/PostgreSQL were still available in my key critical project.
>>> However, when I went to look for DB Manager, it wasn't available.
>>> After some searching, I upgraded to QGIS 3.6 from a non-Fedora
>>> repository (the guidance is here:
>>> https://stackoverflow.com/questions/53716778/the-pyqt4-qtcore-module-failed-to-register-with-the-sip-module)
>>> and now I have access to the DB Manager functionality.
>>> Is the Fedora/QGis community aware of this issue?
>>> Thanks!
>>> Max Pyziur
>>> pyz at brama.com
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
