[Qgis-user] Proportional Symbols Bug in 3.2?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Mar 12 13:35:28 PDT 2019
Not sure, try creating a new field with another format and use the field
calculator to copy the data (this could change the data so please don't
destroy your old fields). I would try with a Int32 or UInt32.
Nicolas
On 2019-03-12 1:39 p.m., Aj Hollenbach wrote:
> Hi Nicolas,
> I looked at the dataset and the "total served" by the water utility is
> indeed in an Integer format. Any other ideas on what might be
> preventing the use of proportional symbols? Perhaps this is bug with
> this version of QGIS?
> Thanks Much,
> Allen
> On Mon, Feb 11, 2019 at 12:58 PM Nicolas Cadieux
> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>
> wrote:
> Perhaps your size field is stored in a text format and not a float
> or int format...
> Look at your” Layer properties, information, Fields.”
> Le 11 févr. 2019 à 12:39, Aj Hollenbach <ajhollenbach at gmail.com
> <mailto:ajhollenbach at gmail.com>> a écrit :
>> Hi QGIS User Community!
>> I am attempting to represent water utilities (points) using
>> *graduated symbols* (by size), and would like the symbols to be
>> *proportional* to the number of customers. I thought that this
>> could be done be done under the symbology dialogue box by
>> selecting "graduated" and then "size" for the method while also
>> using the "*data-defined size legend*" option under the
>> "advanced" sub-menu. However, whenever I click on the "advanced"
>> button and then select "data-defined size legend", I receive an
>> error message that "*data-defined size is not enabled*". Is this
>> a bug in version 3.2, or am I doing something incorrectly?
>> Alternatively, is there another approach creating proportional
>> symbols by size for point data?
>> Thanks Much,
>> Allen
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190312/a6713326/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190312/a6713326/attachment-0001.png>
