[Qgis-user] qlr of spatialite database layer not showing when database is on network drive
Robert Nuske rsn.mailinglists at gmail.com
Thu Mar 21 08:10:52 PDT 2019
Hi Reginald,
SQLite has problems writing on Network File Systems/Samba Shares due to
the poor support for locking. I remember one case where this was
"handled" by writing to a local SQLite file and replace the SQLite file
on the network drive with the local SQLite file after writing finished.
See for instance
https://trac.osgeo.org/gdal/wiki/UserDocs/SQLite
https://www.sqlite.org/faq.html#q5
cheers
   robert (who run into the same problem)
Am 21.03.19 um 16:01 schrieb Reginald:
> Hello list,
> Exporting a spatialite layer to a qlr file when the layer resides in a
> database on a network drive fails every time I try it.
> When I copied this database to my C drive in windows the qlr file shows up
> as it should.
> I have compared the two files and the only difference was the drive letter
> (in this case C was F).
> I tried different notations to acces the network drive (backward slashes ,
> double backward slashes, network acces notation ...) no luck .
> Any ideas why this is not working?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
