[Qgis-user] how to fix the raster calculator
    shalum HOUENOU
    shalumhouenou at gmail.com
    Thu Mar 21 09:19:57 PDT 2019
OK then
Maixent,
De : matteo
Envoyé le :jeudi 21 mars 2019 17:14
À : shalum HOUENOU
Objet :Re: [Qgis-user] how to fix the raster calculator
please answer to all (so you question is forwarded also to the user
mailing list)
I think then the raster calculator has a bug. Could you please report it?
https://issues.qgis.org/projects/qgis
or try to upgrade to QGIS 3.6
On 3/21/19 5:13 PM, shalum HOUENOU wrote:
> Yes I did, as it was mentionned in the training manual, section 8.3.7
> You have the link below :
> https://docs.qgis.org/testing/en/docs/training_manual/rasters/terrain_analysis.html#moderate-fa-using-the-raster-calculator
> Maixent,
> *De : *matteo <mailto:matteo.ghetta at gmail.com>
> *Envoyé le :*jeudi 21 mars 2019 17:07
> *À : *shalum HOUENOU <mailto:shalumhouenou at gmail.com>;
> qgis-it-user-owner at lists.osgeo.org
> <mailto:qgis-it-user-owner at lists.osgeo.org>
> *Objet :*Re: [Qgis-user] how to fix the raster calculator
> Hi Maixent,
>> Indeed the boundaries of my output layer have Strange values
>> ([-1.79769e+308 to 1.79769e+308] instead of [0 1].
>> Thus the output layer is invisible.
>> I’ve already tried to change the max and the min value : The layer is
>> still invisible.
>> What else could I do to fix it ? Any idea ?
> did you also set the reference layer in the algorithm UI?
> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190321/7612f0e5/attachment-0001.html>
