[Qgis-user] Defining Geographical Coordinate System GRS80
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Fri Mar 22 05:09:41 PDT 2019
Hi there,
I have a set of coordinates which are in a user defined projected coordinates system as bellow. Coordinates are in meters.
+proj=sterea +lat_0=53.5 +lon_0=-76.0 +k=0.9996 +x_0=0.0 +y_0=0.0 +a=6378137 +b=6381816.160744 +ellps=GRS80 +units=m +no_defs
The documentation says the data was transformed from Geographical Coordinate System GRS80 in QGIS database with Coordinate Reference Systems and I found one named Unknown datum based upon GRS 1980 ellipsoid with Authority ID EPSG:4019:
+proj=longlat +ellps=GRS80 +no_defs
Is this the GRS 80?
I would like to know if I can relay in CRS with Authority ID EPSG:4019 to transform those projected coordinates back to GRS 80.
Thank you,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l'usage exclusif des personnes ou des organismes à qui ils s'adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l'expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n'assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190322/51bc29c3/attachment.html>
