[Qgis-user] raster smoothing tool?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Mar 22 18:26:58 PDT 2019
That is weird. There are low pass filter in processing. Try one from Saga. Then open Saga and try again. Compare both. If you get the same results, you will know the problem is from Saga or the raster but not from QGIS. Then write back with the exact version of QGIS you are using, on what platform (OS, Linux, Windows...) and what algorithm you are trying. This should help us figure things out.
Nicolas
> Le 22 mars 2019 à 20:27, Yann Troutet <ytroutet at selkirk.ca> a écrit :
> Hello,
> Are there any raster smoothing (low-pass filtering) tools that will work in QGIS 3. Every option that I try simply outputs a raster that has the exact same values as the original.
> This message has been scanned for viruses and dangerous content by
> Selkirk College-E.F.A. Project, and is believed to be clean.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190322/e04c19b6/attachment.html>
