[Qgis-user] WG: Aggregation of adjacent polygons of the same type
Sven Böhme - empirica boehme at empirica-institut.de
Mon Mar 25 02:26:25 PDT 2019
-----Ursprüngliche Nachricht-----
Von: Sven Böhme - empirica
Gesendet: Montag, 25. März 2019 10:25
An: 'Stefan Giese (WhereGroup)' <stefan.giese at wheregroup.com>
Betreff: AW: [Qgis-user] Aggregation of adjacent polygons of the same type
Hi Stefan,
maybe this helps to clarify the problem...
Thanks a lot
Sven
Von: Stefan Giese (WhereGroup) <stefan.giese at wheregroup.com>
Gesendet: Montag, 25. März 2019 10:11
An: Sven Böhme - empirica <boehme at empirica-institut.de>
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Aggregation of adjacent polygons of the same type
Hi Sven,
can you specify your question: what is unclear and where exactly do you need support for?
best regards
stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 2019-03-25 10:04, schrieb Sven Böhme - empirica:
> Hi!
> I'm trying to aggregate neighboring polygons based on additional
> conditions. These are:
> - the polygons must be adjacent
> - the polygons must be of the same type (simple value from attribute)
> - the polygons should only be combined if the values of an attribute x
> are below a certain value AND
> - the polygons shall be merged with other polygons until this value is
> reached
> The polygons are grids. Aggregation should not necessarily lead to new
> squares (as in the Quadtree-method).
> I use PostGIS to store the data and QGIS for visualization and further
> processing. For performance reasons I suspect that a
> database-supported procession makes sense, but if QGIS (GDAL,GRASS
> etc.) offers a function, I would like to try it out.
> I would be happy about support
> Best regards
> Sven
> empirica ag
> Sven Böhme
> Kaiserstraße 29
> 53113 Bonn
> Fon +49 (0)228 91489-90
> Fax +49 (0)3222 95 66 169
> www.empirica-institut.de [1]
> empirica ag - Zweigniederlassung Bonn - HRB 87951 Amtsgericht
> Charlottenburg
> Vorstand: Dr. Marie-Therese Krings-Heckemeier (Vorsitzende),
> Ludger Baba, Dr. Reiner Braun (stellv. Vors.), Meike Heckenroth, Prof.
> Dr. Harald Simons
> Aufsichtsratsvorsitzender: Klaus Arndt
> KOSTENLOSER NEWSLETTER VON EMPIRICA. JETZT ANMELDEN:
> https://www.empirica-institut.de/newsletter-anmelden/ [2] Diese E-Mail
> enthält vertrauliche und/oder rechtlich geschützte Informationen. Wenn
> Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich
> erhalten haben, informieren Sie bitte sofort den Absender und
> vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte
> Weitergabe dieser Mail ist nicht gestattet. - This e-mail may contain
> confidential and/or privileged information. If you are not the
> intended recipient (or have received this e-mail in error) please
> notify the sender immediately and destroy this e-mail. Any
> unauthorized copying, disclosure or distribution of the material in
> this e-mail is strictly forbidden.
> Links:
> [1] http://www.empirica-institut.de/
> [2] https://www.empirica-institut.de/newsletter-anmelden/
> Qgis-user mailing list
Type: image/jpeg
Desc: aggregate_polygons.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190325/598225de/attachment.jpg>
