[Qgis-user] Data volume wms-layer
Andy Harfoot
ajph at geodata.soton.ac.uk
Thu Mar 28 03:25:43 PDT 2019
Hi Pascale,
Just a thought, but the amount of data requested by QGIS from a WMS source may be affected by the 'Oversampling' level, found here: Layer Properties > Symbology > Resampling this is set to 2.00 by default, and reducing it to 1 may reduce the amount of data requested. See here for further info:
https://gis.stackexchange.com/questions/295565/how-does-oversampling-work-in-wmts-layers
The big caveat is the difference between WMS and WMTS, in the former resampling should be done on the server, so QGIS could adopt a hands-off approach, but that may not actually be the case. Something to test anyway!
Cheers,
Andy
On 18/03/2019 11:59, Pascale Hutter wrote:
Hi there,
I’m quite new to QGIS version 3, and was before working with QGIS 2.18. I often use wms-layer, where I purchase a certain data-volume (p. ex. 5’000 pixel) to work with. However, with the new QGIS 3.0 this data volume is used up far more quickly. In QGIS 2.18 it lasted a lot longer. I was wondering if any of you mades some similar experiences? Do you have any idea, if there is a way to change the settings so the data volume would last longer again?
Thank you very much for any suggestions!
Pascale
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190328/486fbd5d/attachment.html>
