[Qgis-user] locating layer
DelazJ
delazj at gmail.com
Sun Mar 31 15:25:20 PDT 2019
I'm neither sure I understand what you want to do but you can give a look
to the locator bar from the status bar (
https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_gui.html#status-bar).
It helps you find a layer in the layers panel or find features (using the
appropriate field.
HTH,
Harrissou
Le dim. 31 mars 2019 à 19:13, Patrick Dunford <enzedrailmaps at gmail.com> a
écrit :
> This comment is difficult to understand. If each polygon is a separate
> layer then it will show up in the layer name, according to what each layer
> is named. If there are multiple polygons per layer, the information about
> them is displayed in a table view.
> On 1/04/19 3:53 AM, Boaz Bar Ilan wrote:
> hallo
> I use 3.4.6
> I have dozens of polygon and I want to be able to locate the the name of
> the polygon in the layer panel
> is there a way ?
> thanks
> boaz
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190401/f75fd2ad/attachment.html>
