[Qgis-user] Dereference plugin not working
damien stephens
damien.stephens at gmail.com
Wed May 1 23:18:13 PDT 2019
Thanks Bertrand.
Yes I am on Windows (10) with a dual monitor setup.
I had already tried the win left and right arrows trick with no success,
and can't find any very small Windows, but tried both again just to check.
No luck unfortunately.
I have tried uninstalling and removing any registry mentions of qgis,
shutting down and reinstalling, but no luck.
Open to any other suggestions.
Thanks
On Thu, 2 May 2019, 05:28 Bertrand Houdusse, <bertrandhoudusse at gmail.com>
wrote:
> Hi Damien,
> If this is related to the classic problem of the Georeferencer's
> disapearing window (almost everi time due to the use of dual screen), and
> if you are on Windows, I recommend you to test this procedure :
> - start Qgis
> - click on the georeferencer button
> - if the window doesn't appear, and if Qgis' main window looses focus,
> that means the focus has gone to the georeferencer's window. So you just
> have to immediatly click this combination : Windows logo key + Left Arrow
> (or WIN + RIGHT ARROW) ; this is the shortcut to maximize the active
> window to the left (or right) side of the screen (link
> <https://support.microsoft.com/en-us/help/12445/windows-keyboard-shortcuts>
> If the georeferencer's windows doesn't show up, you can click the
> combination several times until success
> This usually works fine for many people on Windows (WIN 7 to 10). I don't
> know if there's something similar in Linux or Mac
> If this solution doesn't solve your problem, that may be because the
> georeferencer's window is reduced in a bottom corner of your screen
> (Windows OS again) : you can take a close look at the two corners and
> search for this reduced window, that can be very small.
> Good luck
> Bertrand
> Le mer. 1 mai 2019 à 04:43, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> a écrit :
>> Hi,
>> Could this be a change in QGIS 3.6?
>> https://qgis.org/en/site/forusers/visualchangelog36/index.html#feature-new-option-to-avoid-minimizing-georeferencer-when-adding-points
>> Le 30 avr. 2019 à 21:16, damien stephens <damien.stephens at gmail.com> a
>> écrit :
>> Hi.
>> I am on qgis 3.6.
>> I have been using the referencing plugin for a while with no dramas, but
>> now when I click on the tool button in the raster menu, qgis loses focus,
>> but the georeferencer window does not appear.
>> Have Googled an answer but they are all for qgis v2 and the registry keys
>> they recommend changing are different.
>> My qgis 2.18 copy runs georeferencer fine.
>> Any help much appreciated.
>> Damien
>> On Mon, 29 Apr. 2019, 01:35 Tulika Biswas, <teentulika at gmail.com> wrote:
>>> I have an issue with using the georeferencer.My problem is after adding
>>> co ordinates to the map and giving the transformation settings.. I am
>>> running the georeferencing option.. Then it is being displayed on the
>>> screen as
>>> "Failed to compute GCP points." and the map is also not being shown in
>>> the qgis interface..
>>> Plz help.. Its very urgent..
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190502/4583bd1e/attachment.html>
