[Qgis-user] WFS layer filter - fails to filter on name or abstract
Lars I. Nielsen, LIFA A/S
lin at LIFA.DK
Thu May 9 01:21:21 PDT 2019
Hi list.
When I connect to a WFS source, I get a list of layers to open. The list has 3 columns: Title, Name and Abstract. Most have values in all three.
If the list is long, I want to limit it by a filter, which I specify in the "Filter" text box. The tooltip for this box says, that it'll filter on all/any of the three columns.
But if I enter a string, that only occurs in the name column, but not in the title column, it shows no layers. The same happens with the abstract column.
It seems that the dialog only filter wrt. the title column. This must be a bug, right ?
Using QGis 3.4.5 (Danish)
Med venlig hilsen
GIS-konsulent, FME Certified Professional
[Beskrivelse: C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-Images-Get-L749-l3.gif]
T
6313 6800
lin at lifa.dk
D
6313 6849
W
www.lifa.dk<http://www.lifa.dk>
M
2492 4866
CVR
20937289
Vi tilbyder interne og eksterne kurser. Du kan finde mere information i vores kursuskalender<https://www.lifa.dk/kursuskalender>
[Beskrivelse: C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png]<https://www.linkedin.com/company/lifa-a-s/>
Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190509/0f7ce97f/attachment.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190509/0f7ce97f/attachment.gif>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190509/0f7ce97f/attachment.png>
