[Qgis-user] Unable to launch QGIS with X Forwarding - Can Not make qgis.db private copy
Jürgen E. Fischer jef at norbit.de
Sun May 19 08:27:04 PDT 2019
Hi Amedeo,
On Sun, 19. May 2019 at 16:58:49 +0200, Amedeo Fadini wrote:
> I have found only the user profile under /root and not under
> /home/<myuser>...
> It works if I connect with ssh -X root@<myserver>
The profile should be created automatically.  Check whether one of the parent
directories of ~/.local/share/QGIS/QGIS3/profiles is not writable by your user
- that might be a result of copying a profile earlier or running something
as root without resetting HOME.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190519/4e43b359/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190519/4e43b359/attachment.ksh>
