[Qgis-user] Fw: KMZ
Stefan Giese Stefan.Giese at wheregroup.com
Sun May 19 23:28:32 PDT 2019
from the menu just use Project -> Import/Export -> Export Map to Image
and your map will be saved as an image (tif, jpg, png...) with or
without a world file (for georeference)
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 20.05.2019 um 04:58 schrieb Lukas Sadler:
> another question, pretty please
> how does one export a clip of a base map layer as a reference jpeg/Tiff
> I've tried 'clip raster by extent' but when i run it it says 'layers
> were not correctly generated'
> ----- Forwarded Message -----
> *From:* Lukas Sadler <lukas_sadler at yahoo.com>
> *To:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>; Brent
> Wood <brent.wood at niwa.co.nz>
> *Sent:* Monday, May 20, 2019, 2:39:05 PM GMT+12
> *Subject:* Fw: [Qgis-user] KMZ
> Okay
> I got it to work
> project and base map layer needs to be in WGS 84/Pseudo-Mercator with
> KMZ file set as WSG 84
> Wood <Brent.Wood at niwa.co.nz>
> *Sent:* Monday, May 20, 2019, 2:26:16 PM GMT+12
> *Subject:* Re: [Qgis-user] KMZ
> thanks guys
> but still not doing the trick
> I've got everything in 4326 and the KMZ is still not sitting in the
> correct location
> the location is in New Zealnd but if i use 4326 it looks like it sits
> on the opposite longitude
> On Monday, May 20, 2019, 2:14:17 PM GMT+12, Brent Wood
> <Brent.Wood at niwa.co.nz> wrote:
> I think KMZ supports lat/long coords only... Google doesn't really
> understand projections...
> Make sure your KMZ layer has EPSG:4326 as its projection
> HTH
> Brent Wood
> Programme leader: Environmental Information Delivery
> NIWA
> DDI:  +64 (4) 3860529
> <http://www.niwa.co.nz>
> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> T +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade, Greta Point, Wellington
> Connect with NIWA: niwa.co.nz <https://www.niwa.co.nz>Facebook
> <https://www.facebook.com/nzniwa>Twitter
> <https://twitter.com/niwa_nz>LinkedIn
> <https://www.linkedin.com/company/niwa>Instagram
> <https://www.instagram.com/niwa_science>
> To ensure compliance with legal requirements and to maintain cyber
> security standards, NIWA's IT systems are subject to ongoing
> monitoring, activity logging and auditing. This monitoring and
> auditing service may be provided by third parties. Such third parties
> can access information transmitted to, processed by and stored on
> NIWA's IT systems.
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of
> *Sent:* Monday, May 20, 2019 13:45
> *Subject:* [Qgis-user] KMZ
> Hi,
> I've tried importing KMZ files from google earth into a project on
> QGIS (3.6.3 Noosa) but the files don't project in the same location
> even if i set it to the project's CRS
> what should i do to have the KMZ files projecting in the correct location
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/23b18088/attachment.html>
