[Qgis-user] las files
    Alexander Bruy
    alexander.bruy at gmail.com
    Mon May 20 03:20:47 PDT 2019
There is also WhiteboxTools.
пн, 20 трав. 2019 о 12:35 Andreas Neumann <a.neumann at carto.net> пише:
> Hi Tony,
> Basically you have two options for using/converting LAS/LAZ files in QGIS:
> * LasTools (commercial, requires license), integrated in QGIS processing
> toolbox
> * PDAL (OpenSource), not yet properly integrated in QGIS processing toolbox
> If all you need is a LAS/LAZ viewer there is also plas.io where you can
> load and view a LAS/LATZ directly in a modern web browser with WebGL
> support.
> If you want to go the "free" route you'll have to use PDAL outside of QGIS
> (on the command-line) and convert them to GeoTIFF files. Have a look at the
> PLAS tutorials at https://pdal.io/tutorial/index.html
> There are very loose, not yet concrete, plans to better integrate PDAL in
> the QGIS processing toolbox, and there is even a QGIS plugin for that in
> the very early stages. If you are adventurous you could try if it works for
> you.
> Greetings,
> Andreas
> Am 20.05.19 um 09:10 schrieb Tony Shepherd (FarmMaps NZ):
> Hi All
> I'm new to QGIS after using MapInfo for more years than I dare to admit
> and finding QGIS great.  I’m making full use of the 3D features as I work
> mainly in the forestry industry and as they say, a picture says a thousand
> words, particularly when showing topography.  My question is, I am trying
> to find a way of converting some LiDar data that I have (las files) to
> something that QGis can use when creating 3D views.  Currently I’m using
> tif DEM files, so can anyone point me in the right direction to creating a
> dem from las files?  I can't see any plugins so wonder how others are
> achieving this?
> Cheers
> Tony
> *Tony Shepherd*  *|*  GeoSpatial
> Ph 027 435 6193  *|*  E tony at farmmaps.nz
> FarmMaps NZ, 3 Kerwood Place, Gore 9740
> [image: FM_logo1_small (Custom)]
> <http://tonyshepherd8.wixsite.com/home>
> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>
> Qgis-user mailing listQgis-user at lists.osgeo.org
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/e6d3aebe/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/e6d3aebe/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/e6d3aebe/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190520/e6d3aebe/attachment-0001.png>
