[Qgis-user] CRS / reprojection problems
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue May 21 06:37:37 PDT 2019
99 % of the time, the data is the problem because it’s in the wrong crs.  Right click on the problem layer in the layer panel and change the layer crs to what is should be.  Use a google or other base map from quickmap plugin.  That should permit you to find the correct CRS.
Sometimes, crs will have problems reprojecting across some latitudes or longitude (like projections make for the poles).  In that case, reprojecting the data using the “save as” option will solve the problem.
Nicolas
> Le 20 mai 2019 à 21:53, Matt Boyd <mattslists at gmail.com> a écrit :
> Hi QGISers,
> I'm having an issue with reprojecting things in QGIS.
> Installer OSGEO64W
> Latest version and LTS both have same issue.
> Issue:
> reprojection just isn't working. If I load a data set with decimal degrees and another with a projected coordinate system the data (points / lines / polygons) will only display if the basemap is in the same projection system.
> This is happening across 2 PCs, (windows10) and the LTS and latest versions of QGIS. Has anyone got some troubleshooting tips?
> Thanks
> Matt
> Qgis-user mailing list
