[Qgis-user] Antw: Developing an "Action" that shows changed value of a form-field
Kai Behncke
Kai.Behncke at ibbenbueren.de
Mon May 27 07:53:54 PDT 2019
Well, it`s not an action, but I found a solution a home-made formular:
from qgis.PyQt.QtWidgets import
QWidget,QLineEdit,QPushButton,QDialogButtonBox
from PyQt5.QtCore import *
from PyQt5.QtGui import *
def my_form_open(dialog, layer, feature):
geom = feature.geometry()
control = dialog.findChild(QLineEdit, "z")
#layer = qgis.utils.iface.activeLayer()
global myDialog
myDialog = dialog
global myFeature
myFeature= feature
buttonBox = dialog.findChild(QDialogButtonBox,"buttonBox")
#buttonBox.accepted.disconnect(myDialog.accept)
#Wire up our own signals.
buttonBox.accepted.connect(validate)
#buttonBox.rejected.connect(myDialog.reject)
# Wire up our own signals.
#pushButton.accepted.connect(validate)
def validate():
qgis.utils.iface.messageBar().pushMessage("Autosave", u"Validalli :
#qgis.utils.iface.messageBar().pushMessage("Autosave", u"blba :
"+z.text())
z = myDialog.findChild(QLineEdit, "z")
myFeature['z'] = z.text()
layer.updateFeature(myFeature)
layer.commitChanges()
Mit freundlichen Grüßen
Im Auftrag
Kai Behncke
Geoinformation
Tel.: +49 5451 931-7125
E-Mail: kai.behncke at ibbenbueren.de
Rathaus II
Roncallistraße 3-5
1. Stock, Raum 105
49477 Ibbenbüren
>>> "Kai Behncke" <Kai.Behncke at ibbenbueren.de> 27.05.2019 13:04 >>>
Dear users,
for a vector-layer I would like to produce an action, that shows the
changed value in a formular.
E.G. I am editing a vector-point-layer, click on a point, the fomular
is opening. I change a value (lets say
the formular-field "z" had a value "test" and I change it to "test2").
Then I start my developed action.
I tried for example:
from qgis.PyQt import QtWidgets
QtWidgets.QMessageBox.information(None, "Feature id", "feature id is [
$z ] '%Z%' '%z%' $z [z] $Z [Z] [%z%] [%Z%]")
but I always get the "old" value "test" and not the formular-changed
value "test2".
Has anybody an idea what I can do?
Thank you in advance, Kai
Im Auftrag
Kai Behncke
Geoinformation
Rathaus II
Roncallistraße 3-5
1. Stock, Raum 105
49477 Ibbenbüren
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190527/8dc026bc/attachment.html>
