[Qgis-user] New Coordinate Conversion Tool in Lat Lon Tools
C Hamilton adenaculture at gmail.com
Wed May 29 05:49:11 PDT 2019
Mike,
Thank you for your comments. Lat Lon Tools defaults to the (lat, lon) order
but that can be changed in the settings. ESRI uses the lon,lat order and it
seems like most everyone else uses the lat,lon order.
I don't think the QGIS coordinate display can be changed although perhaps
the developer team should consider making that an option. There is a reason
some of us, including myself, prefer the lat,lon order.
In Lat Lon Tools, if you select the "Copy Latitude, Longitude" tool, it
will display the coordinate in the bottom bar in the lat,lon order or the
order of your choice. Of course if you click on the map it will also copy
it to the clipboard.
For your need for the DMS to be in the format of "442220N086111W" I will
add a separate setting just for that format that specifies the delimiter
and if it is blank then it will be like you want.
I welcome any other input that would improve this tool.
Calvin
On Tue, May 28, 2019 at 5:42 PM Mike Flannigan <mikeflan at att.net> wrote:
> That is an amazing plugin.?? Thank you.
> It is going to help me out a whole bunch.
> I like that you have lat,long, and not long,lat in
> the DD format.?? Outside of the plugin, in the status
> bar at the bottom of my Windows QGIS, and across from
> "Coordinate:", QGIS lists long,lat in the DD format.
> I've been trying to change that to lat,long but have
> been unable to do that so far.?? Anybody know how to
> do that?
> The coordinate conversion box is incredible too.
> Very nice design.?? The only thing I would like to
> do that I cannot figure out is to change the DMS
> format from
> 44??22'20" N,86??1'11" W
> to
> 442220N086111W
> But I can easily do that with scripts outside of QGIS,
> so it is no big deal to me.
> Now I am going to look at your Search Layers plugin.
> I think I have a need for that too.
> Thanks for all you do.
> Mike
> On 5/28/2019 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> > I have added a new coordinate conversion tool to the "Lat Lon Tools"
> > plugin. It is somewhat similar to the capabilities you find with the
> ArcGIS
> > coordinate conversion tool. You can manually copy and paste or type in a
> > coordinate in one of the various formats and it will convert it to all
> the
> > others. You can also click on the map to get the same results. Here is
> the
> > plugin:
> > http://plugins.qgis.org/plugins/latlontools/
> > These are the formats that are currently available:
> > WGS 84 latitude & longitude
> > Project CRS
> > Custom CRS
> > D?? M' S"
> > DDMMSS
> > Standard UTM
> > MGRS
> > Google Plus Codes
> > Give it a try and let me know what you think.
> > Thanks,
> > Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190529/693e9829/attachment.html>
