[Qgis-user] slope cellsize under 0,6
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sat Nov 2 10:41:56 PDT 2019
Is your original data in latitude and longitude? If so, you will need a z factor to have a realistic output. To see if this is a problem, save the data in a local UTM and try again. If your xy is in long/lat and z is in meters, you need a z factor.
Nicolas
> Le 2 nov. 2019 à 11:59, Carolina Rey <carredy at hotmail.com> a écrit :
> Hello everyone,
> I tried to produce a slope from a DEM with under 0,6 m resolution. QGIS fulfills the task but the result isn't realistic.
> I tried to produce another slope from DEM 30m and then change the cell size with "resampling" but the task could't be fulfilled.
> Could it be that the pixel size 0,6x0,6 is to small? It may be a problem of the origin of the image. I used the screenshot option of google earth pro.
> Thanks for the help
> Carolina
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191102/0e527c31/attachment.html>
