[Qgis-user] WMS Problem in QGIS 3.10
Nick Hopton nhopton at gmail.com
Fri Nov 8 04:13:57 PST 2019
I have problems with loading UK Environment Agency WMS layers. This has only
arisen since I installed QGIS 3.10.
I understand that when QGIS makes a WMS request it adds the current version
to the User-Agent string, so in version QGIS 3.10.0 this results in
"Mozilla/5.0 QGIS/3.10.0-A Coruña" and that it might be the "ñ" character
that's causing the request to be rejected.
For testing purposes here is a typical EA WMS request:
https://environment.data.gov.uk/spatialdata/lidar-composite-digital-surface-model-dtm-1m/wms
I've reported the problem to the EA, but I wonder if I should report it as a
QGIS bug as well?
All of the above assumes that it is the extended set character that is
causing the problem and of course this might not be the case.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
