[Qgis-user] Layer Labeling Color Issue
Alexandre Neto senhor.neto at gmail.com
Fri Nov 8 16:42:20 PST 2019
Check this link:
https://oslandia.com/en/2017/10/17/auxiliary-storage-support-in-qgis-3/
I believe you can revert the custom color for all labels by removing
auxiliary data field that controls the font color.
In case you want to use that again, you may need to add it back, but
meanwhile all values should be cleaned.
Let me know if it works.
Alexandre Neto
QGIS Support
www.QCooperative.net
A sexta, 8/11/2019, 18:08, Village Code Enforcement <
codes at villageofliverpool.org> escreveu:
> Hello,
> I am using QGIS Version 3.4.10-Madeira.
> In Label Layering Options I set my label layering color to yellow. I then
> used the Change Label button to change the color of a few labels to
> green. Later I decided to change all the label colors to blue using Label
> Layering Options​, but the labels I custom colored green remain green. Of
> course I can manually change them to blue one at a time but I want to "turn
> off" the custom color so that utilizing Label Layering Options will again
> affect the color of all of the labels. I can't find a way to make this
> happen.
> Bill
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191109/d991c2ee/attachment.html>
