[Qgis-user] Can't find the the Print Composer window while creating a basic map layout in QGIS 3.4 Madeira
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Nov 12 20:53:08 PST 2019
Just right click on the layout and you will be able to select the correct size.
Nicolas
> Le 12 nov. 2019 à 23:26, Donald Meier <dhmmeier at gmail.com> a écrit :
> Thanks. Unfortunately I can't figure out how to use Layout Manager to frame the layout so I can export for specific large paper size. Any ideas?
>> On Tue, Nov 12, 2019, 10:11 PM Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
>> Hi,
>>  Print composer is now layout manager. Look for « layout » under project.
>> Nicolas
>> > Le 12 nov. 2019 à 22:25, Donald Meier <dhmmeier at gmail.com> a écrit :
>> > I am trying to lay out a map to export and print at a larger size, approximately 24 x 36 inches or A1. The help tutorial for the version says to followthhis path:  Projects -> Layouts ->  Composer Manager -> Print Composer. In my version there is no Composer Manager or Print Composer in any menu I can find. Can anyone help with this?
>> > Thanks in advance!
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191112/7a04f36d/attachment.html>
