[Qgis-user] How set real origin on a false origin dataset
Alexandre Neto
senhor.neto at gmail.com
Sun Nov 17 15:22:29 PST 2019
Another possible solution it's to create a custom projection where you
include the false origin information (false northing and false easting.
Then set your layers to use that custom projection.
For more information on how to create a custom projection in QGIS, check
this page of the official documentation:
https://docs.qgis.org/3.4/en/docs/user_manual/working_with_projections/working_with_projections.html#id12
For more information about the false northing and easting, check PROJ
documentation:
https://proj.org/usage/projections.html?highlight=false%20north#false-easting-northing
Alexandre Neto
QGIS Support
www.qcooperative.net
A domingo, 17/11/2019, 10:10, Lens Paul <paul.lens at gmx.com> escreveu:
> Hi Andrea,
> False origins happens often with local topographical surveys, with also a
> false altitude origin. Architectural plans are sometimes even more tricky:
> rotated, or with a centimetric or millimetric scale instead of a metric
> scale. A way is to transform the data with a CAD software when available.
> Even then, problems can arise e.g. when rescaling some objects.
> I suppose a workaround in your case would be to use the "move" command
> and to snap to a point drawn at the correct coordinates. This could be
> cumbersome when there are many layers to edit, which is often the case,
> unless you import the dxf as a unique layer....
> If your data consist merely of point data (no polylines), it should be
> possible, after conversion of the dxf in a shapefile, to create the X, Y
> attributes using the field calculator, and to recalculate these attributes
> with the same tool.
> In the case of polylines, there is the possibility to extract vertices.
> But I do not know if there is a possibility to recreate the polylines after
> the recalculation of the X, Y attributes.
> Dxf conversion is a complicated subject. The evolution of the capabilities
> of QGIS in that field is amazing. Many thanks to the developers for that.
> Hope this helps,
> Paul
> Le 13/11/2019 à 14:04, Andrea Peri a écrit :
> Hi,
> We have a dxf containings geograph data in false.origin .
> I'm searching a solution to put a kind of origin (x,y) to sum to every
> point of the data. Is possible to set an origin.to a dataset in qgis ?
> Thx.
> Andrea.
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191117/a66a78b3/attachment.html>
