[Qgis-user] PostGIS- erroneous query : Unable to get list of tables from DB
Jason Carlson
jason at starlandcounty.com
Tue Nov 19 06:18:17 PST 2019
The error message would still suggest it is an access problem to the
topology table. Perhaps you need to take it a step further with your
postgres version and grant select to the user.
Not at my computer now but try something along the lines of:
GRANT SELECT ON topology TO username;
On Mon., Nov. 18, 2019, 5:10 p.m. Laurence Béchet, <
bechet.laurence at gmail.com> wrote:
> Thank you Jason for your answer.
> I've granted usage on schema topology to my user -> same problem. I even
> granted PUBLIC.
> There is something 'wrong' with the passed request itself as it fails in
> pgadmin as well (see it below).
> I have a very basic test.qgz file. I launch it with 3.4.13 (I've updated
> all my qgis versions), open the browser, connect to my db and see the
> tables. Same file, launched with 3.10.0, open browser, connect to my db
> (same profile so I guess same qgis-auth.db file I suppose) and get the
> 'failed to get layers' as described in the bug. I can see the sql request
> which failed and that one doesn't work either in pg_admin. Unfortunately
> the sql request passed with 3.4.13 is not displayed.
> SELECT
> l.f_table_name,l.f_table_schema,l.f_geometry_column,upper(l.type),l.srid,l.coord_dimension,c.relkind,obj_description(c.oid),array_agg(a.attname),
> count(CASE WHEN t.typname IN
> ('geometry','geography','topogeometry','raster') THEN 1 ELSE NULL END) , 1
> FROM geometry_columns l,pg_class c,pg_namespace n,pg_attribute a,pg_type t
> WHERE c.relname=l.f_table_name AND l.f_table_schema=n.nspname AND NOT
> a.attisdropped AND a.attrelid=c.oid AND a.atttypid=t.oid AND a.attnum>0 AND
> n.oid=c.relnamespace AND has_schema_privilege(n.nspname,'usage') AND
> has_table_privilege('"'||n.nspname||'"."'||c.relname||'"','select') GROUP
> BY 1,2,3,4,5,6,7,c.oid,11 UNION SELECT
> l.f_table_name,l.f_table_schema,l.f_geography_column,upper(l.type),l.srid,2,c.relkind,obj_description(c.oid),array_agg(a.attname),
> FROM geography_columns l,pg_class c,pg_namespace n,pg_attribute a,pg_type t
> l.table_name,l.schema_name,l.feature_column,CASE WHEN l.feature_type = 1
> THEN 'MULTIPOINT' WHEN l.feature_type = 2 THEN 'MULTILINESTRING' WHEN
> l.feature_type = 3 THEN 'MULTIPOLYGON' WHEN l.feature_type = 4 THEN
> 'GEOMETRYCOLLECTION' END AS type,(SELECT srid FROM topology.topology t
> WHERE l.topology_id=t.id),2,c.relkind,obj_description(c.oid),array_agg(a.attname),
> FROM topology.layer l,pg_class c,pg_namespace n,pg_attribute a,pg_type t
> WHERE c.relname=l.table_name AND l.schema_name=n.nspname AND NOT
> l."table",l."schema",l."column",'POLYGON',l.srid,2,c.relkind,obj_description(c.oid),array_agg(a.attname),
> FROM pointcloud_columns l,pg_class c,pg_namespace n,pg_attribute a,pg_type
> t WHERE c.relname=l."table" AND l."schema"=n.nspname AND NOT a.attisdropped
> l."r_table_name",l."r_table_schema",l."r_raster_column",'RASTER',l.srid,2,c.relkind,obj_description(c.oid),array_agg(a.attname),
> FROM raster_columns l,pg_class c,pg_namespace n,pg_attribute a,pg_type t
> WHERE c.relname=l."r_table_name" AND l."r_table_schema"=n.nspname AND NOT
> BY 1,2,3,4,5,6,7,c.oid,11 ORDER BY 2,1,3
> I have postgresql 9.6, postGIS 2.3
> Kind regards
> Laurence
> On 19/11/2019 4:28 AM, Jason Carlson wrote:
> I think your issue sounds like what I experienced and from what I dug up
> it can be as simple as what version of Postgres you were using (I was using
> Postgres version 10.10) not allowing any access to the "topology" schema.
> https://github.com/qgis/QGIS/issues/32483
> I fixed by running the following SQL command (replace *USERNAME as the
> username* you are using to connect to postgres):
> *GRANT USAGE ON SCHEMA topology TO USERNAME;*
> it was also suggested you could instead give access to public but I'm not
> sure if that is as secure but maybe other issues are created if public
> doesn't have access, this is not my area of expertise.
> GRANT USAGE ON SCHEMA topology TO PUBLIC;
> Hope that helps.
> *Jason Carlson*
> On Fri, Nov 15, 2019 at 7:30 PM Laurence Béchet <bechet.laurence at gmail.com>
> wrote:
>> Good afternoon,
>> Windows 8.1 pro 64 bits
>> QGIS version 3.10.0-A Coruña QGIS code revision 6c816b4204
>> I have a postgresql db with Postgis enabled to which I connect using a pg
>> service.
>> It was working fine with the default profile.
>> I created a new profile (settings/user profiles). My projects were still
>> displayed (tables located in the db) and looked ok.
>> But when I wanted to add a new table from datasource manager/postgresql I
>> was prompted the first time to create a connection. I created the same one
>> as I had for the default profile. I tested the connection and it passed. I
>> clicked to 'connect' and nothing happened: no table list displayed. I
>> checked with DB/DB manager and I can see my tables.
>> I switched back to the former default profile: same behaviour (no tables
>> listed).
>> There are different qgis-auth.db files (different sizes) in each profile
>> folder of C:\Users\<myuser>\AppData\Roaming\QGIS\QGIS3\profiles (don't know
>> how to read them though)
>> In the logs I found the following messages (PostGIS section):
>> 2019-11-16T12:27:02 WARNING NOTICE: row number 0 is out of range
>> 0..-1
>> 2019-11-16T12:28:20 WARNING Erroneous query: <long query> [ERROR:
>> permission denied for schema topology
>> 2019-11-16T12:28:20 WARNING NOTICE: WARNING: there is no
>> transaction in progress
>> 2019-11-16T12:28:20 WARNING Unable to get list of spatially
>> enabled tables from the database
>> I don't have any problem with the default user and QGIS version
>> 3.4.13-Madeira
>> (I have not tried to create another profile with 3.4.13 because I need a
>> working version of qgis).
>> The error message seems to point toward a lack of permission, but that
>> same user can run that query within pgadmin without any problems.
>> Any idea where to look? I looked on internet but to no avail ...
>> Thank you in advance
>> Laurence Bechet
>> *ARK IN THE PARK Volunteer Co-Ordinator*
>> *Cascades Ranger Station*
>> * Falls Road, Waitakere*, Auckland
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> *Starland County*
> *Morrin, AB *
> *(403) 772-3793*
> *www.starlandcounty.com <http://www.starlandcounty.com>*
> *Our organization accepts no liability for the content of this email, or
> for the consequences of any actions taken on the basis of the information
> provided, unless that information is subsequently confirmed in writing. The
> content of this message is confidential. If you have received it by
> mistake, please inform us by an email reply and then delete the message. It
> is forbidden to copy, forward, or in any way reveal the contents of this
> message to anyone. *
*Starland County*
*Morrin, AB *
*(403) 772-3793*
**www.starlandcounty.com
<http://www.starlandcounty.com>**
liability for the content of this email, or for the consequences of any
actions taken on the basis of the information provided, unless that
information is subsequently confirmed in writing. The content of this
message is confidential. If you have received it by mistake, please inform
us by an email reply and then delete the message. It is forbidden to copy,
forward, or in any way reveal the contents of this message to anyone. *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191119/64d95f37/attachment-0001.html>
