[Qgis-user] Request methods
Mathieu Gillot mathieu.gillot at larbre-ingenierie.fr
Tue Oct 1 23:15:04 PDT 2019
Hello,
In my project I need to compare the result of the concatenation of two
fields, A and B, in common between two different layers.
For he moment, I'm using a calculated field in each layer to concatenate
the two fields. Then a sql request in a virtual layer compare them.
Improving my sql abilities, I noticed that I could do that with a single
virtual layer and a sql request with two sub requests to concatenate the A
and B fields and the primary request to compare them.
My question :
1 - what is the more lightweight solution with large sets of data ?
I noticed that sql requests could seriously slow down qgis. But calculated
fields have to be calculated too...
2 - I do not really master external database solutions yet (I'm using
geopackage and project relations between tables). In fine, is a postgresql
DB could be a solution in term of velocity ? Are the Qgis VL layers have an
equivalent in that kind of database, or must I create them anyway into the
SIG ?
Thanks for any help.
Mathieu G
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191002/67c44d0c/attachment.html>
