[Qgis-user] Merge does work (at least not as I expect)
Alexandre Neto senhor.neto at gmail.com
Wed Oct 2 08:41:49 PDT 2019
Using your layer directly into merge lines algorithm worked properly on
QGIS 3.4 in Linux. That is, in the end, I got one single feature that is no
longer multi. (if I try to go multipart to single part I can't get the
individual segments).
What does not work (but it's intended) is if you have a layer full of
single segments that connect to each other and try to merge them together
using "merge lines". In that case, I needed to dissolve all layers first,
and then use the merge line tool.
Hope it helps,
Alexandre Neto
On Wed, Oct 2, 2019 at 4:18 PM <qgis-user at stripfamily.net> wrote:
> On 10/2/2019 12:33 AM, Alexandre Neto wrote:
> > Hi,
> > Can you provide a sample of your data?
> > What version of QGIS are you using? What OS?
> QGIS 3.4.2 on Windows 7 Pro, 64 bit
> Full dataset is attached.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191002/9ecfe63c/attachment.html>
