[Qgis-user] QGIS v3.8.3 Map Views
upland at mcsnet.ca upland at mcsnet.ca
Mon Oct 7 14:27:38 PDT 2019
Hello,
I'm new to QGIS and was working with ArcGIS pro before.  I'm switching to
QGIS since its much more user friendly and I like the versatility of use.
I'm trying to work with multiple map views and putting them into a layout.
When I generate a new map view from the view menu and rename it, set a theme
for the layer visibility and data to be shown.
Then I do into my layout and that map view does not show up when I go to the
"add new map".  I can add a new map but it only shows up identical to the
main view and as I add maps to the layout they are
Named Map 1,  Map 2, etc..  My custom map view I created with its unique
name is not there in the dropdown menu.
Question is how do I get my custom map views that I created with custom
theme to show up in the layout function and add it to my layout?
Thanks very much for any input you may have.
Upland Environmental Ltd
Normand Menard R.P.F.T  C.Tech (Eng)
Box 750, Plamondon, Ab  T0A 2T0
Ph: 780-798-2200,  Cell: 780-404-3855
Email:  <mailto:upland at mcsnet.ca> upland at mcsnet.ca
 <http://www.uplandenvironmental.ca/> www.uplandenvironmental.ca
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191007/61754efe/attachment.html>
