[Qgis-user] QAD plugin QGIS 2.14.4 - Dimenstion style text layer disabled
Nyall Dawson
nyall.dawson at gmail.com
Tue Oct 8 23:37:22 PDT 2019
On Tue, 8 Oct 2019 at 23:34, Jochem Beullens <jochem.beullens at geoit.be> wrote:
> Dear,
> I am trying to use the QAD plugin in QGIS 2.14.4 to add dimensions to my layers.
Just a warning: 2.14 is ancient -- you should NOT be using this version.
Nyall
> To add dimensions I need to create a dimension style first. For a dimension style I need a text layer, a symbol layer and a line layer.
> I created these layers (tables) in PostGIS using the SQL statements out of the following document (file:///C:/Users/Jochem/.qgis2/python/plugins/qad/help/help_en/index.html#Text%20layer%20model%20for%20dimensioning%3A).
> Next I made a PostGIS connection in QGIS and added the layers dim_symbol, dim_line and dim_text. Now I can create my dimension style and set the lines on the dim_line layer, the symbols and arrows on the dim_symbol layer, but the txt layer stays disabled and I can not select the dim_text layer.
> What can be the problem here?
> Met vriendelijke groeten - meilleures salutations
> Jochem Beullens
> CAD & GIS Adviseur
> Consultant CAO & SIG
> +32 (0)3/280 00 57 (#4)
> +32 (0)498/64 81 78
> Geo-IT BVBA – SPRL | BE0867.526.230 | www.geoit.be
> Potvlietlaan 5B - 2600 Antwerpen | Blvd Paepsem 20 – 1070 Bruxelles
> Qgis-user mailing list
