[Qgis-user] QGis 3.8 : Still not possible to export maps in multilayer pdf format ?
Jürgen E. Fischer
jef at norbit.de
Thu Oct 10 05:35:34 PDT 2019
Hi Stefan,
On Thu, 10. Oct 2019 at 14:23:51 +0200, Stefan Giese wrote:
> it will be available from version 3.10.
if build against GDAL 3.
> You can test it with the nightly build 3.9 developer versions (use osgeo4W
> setup)
Which is using the GDAL 3 nightly, which in turn requires PROJ >=6 (which is
provided by the proj nightly of 7 in osgeo4w). PROJ 6 and GDAL 3 are however
not yet supported by GRASS (see https://github.com/OSGeo/grass/pull/136),
therefore the "regular" GDAL is still 2…
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191010/159047f4/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191010/159047f4/attachment.ksh>
