[Qgis-user] Movement patterns
Anita Graser
anitagraser at gmx.at
Tue Oct 15 13:28:11 PDT 2019
This should have gone to the list:
On Tue, Oct 15, 2019, 21:34 Anita Graser <anitagraser at gmx.at> wrote:
> Dear Falk,
> On Tue, Oct 15, 2019 at 8:59 PM Falk Huettmann <fhuettmann at alaska.edu>
> wrote:
>> Hi Anita,
>> thanks, I looked at it but have a hard time to see and understand
>> details, e.g. how done, and what the actual items perform.
>> Would you have some insights ?
> Input point layers have to contain a trajectory (or moving object) ID and
> timestamps.
> - Add heading to points takes a point layer and adds a heading column
> based on the direction of the line between consecutive points
> - Add speed to points takes a point layer and adds a speed (m/s) column
> based on the distance and time difference between consecutive points
> - Trajectories from point layer takes a point layer and creates a line
> layer by connecting consecutive points
> - Day trajectories from point layer does the same as Trajectories from
> point layer but creates one line for each day. So if your observations
> contain multiple days, you'll get more shorter lines.
> There is sample data in the plugin folder. On Windows, the path is
> something like:
> C:\Users\anita\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\processing_trajectory\sample_data
> Hope this helps.
> Regards,
> Anita
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191015/c421bb18/attachment.html>
