[Qgis-user] Distance between the edges of two polygons
    Tim Sutton
    tim at kartoza.com
    Wed Oct 16 11:48:20 PDT 2019
Hi Patrick
Feel free to contact me off-list and set up a VOIP session and I will try to help you.
Greetings from someone doing similar things to you….
Regards
Tim
> On 16 Oct 2019, at 10:12, Patrick Marx <patrick.marx at gmx.de> wrote:
> Hi, I would like to know the direct distance between the edges of two polygons which lay on different contour lines. We are planning a permaculture project with swales along different contour lines. Between the swales on different contour lines we will create vegetable beds. Because we need a minimum width of the beds, we need to know on which contour lines we could plan the swales. If we lay the swales on contour lines with a hight difference of 10 metres the beds will be wider as we choose 5 metres. How could we use QGIS for that problem? I have a DEM with a raster of 1m. I think I know how to create contour lines from it in a first step. But I don't know how to continue because I am relatively new in using QGIS.
> Thank you for your suggestions!
> Best regars,
> Patrick
> Holen Sie sich Outlook für Android <https://aka.ms/ghei36>_______________________________________________
> Qgis-user mailing list
Tim Sutton
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191016/4722296c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191016/4722296c/attachment.png>
