[Qgis-user] assign a symbol based on property in layer
DelazJ
delazj at gmail.com
Wed Oct 23 16:48:37 PDT 2019
Hi Matt,
In the vector layer properties, categorized symbology, at the bottom right
of the dialog, you have an "Advanced" drop-down menu with options like "*Match
to saved symbols" *or *"Match to symbols from file"* that should help you
achieve what you want.
Regards,
Harrissou
Le jeu. 24 oct. 2019 à 01:35, Matt Boyd <mattslists at gmail.com> a écrit :
> Hi QGISers,
> I've got some shapefiles that have a symbology reference embedded in them.
> I've also got a set of symbols that have the same name as the specific
> symbology references. I haven't been able to work out how to get qgis to
> automatically select the symbology reference. I can manually assign each
> one and then save that as a qgis style for use later but there are a lot of
> these and I possibly have other use cases.
> This would be useful for assigning colours based on geology in surface
> maps.
> Any tips?
> Thanks
> Matt
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191024/9ba0779a/attachment.html>
