[Qgis-user] Map Software Query
    Jonathan Moules
    jonathan-lists at lightpear.com
    Fri Oct 25 14:47:37 PDT 2019
Hi Gaurav,
This should definitely be do-able with QGIS. It sounds like a simple
"Point in polygon" join (or a "spatial join"). If you google that you
should find a few tutorials.
Cheers,
Jonathan
On 22/10/2019 14:46, Gaurav Khatri wrote:
> Hi,
> I am trying to build a software where I can plot points by agents and
> their prospect addresses on a map.
> After plotting the points I would like to draw a polygon around that
> agent and give him those particular names whose points are under that
> polygon, to the agent to work further.
> Kindly let me know if this is possible to build using QGis or I should
> use some other software.
> Any help is appreciated, thank you.
> Regards,
> Gaurav
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191025/fcafbde5/attachment.html>
