[Qgis-user] Densify Techniques with QGIS
C Hamilton
adenaculture at gmail.com
Mon Oct 28 08:42:12 PDT 2019
Tim,
The Shape Tools plugin has a geodesic densify function that adds in points
based on a maximum desired distance between vertices. If any line or
polygon segment is longer then than the maximum distance it will add in
extra vertices along the geodesic path (shortest distance along the earth's
surface) to make sure no segment longer than that distance.
Calvin
On Mon, Oct 28, 2019 at 5:13 AM Tim Makins <tsg.makins at gmail.com> wrote:
> Please can someone advise me on the techniques for densifying polygon
> shapefiles with QGIS. I understand that I need to do this when, for
> instance, adding a square polygon with just 4 corner vertices on to a
> Azimuthal Orthographic projection, so that the lines follow the
> meridians correctly.
> The 'Densify by Count' tool lets me add more vertices as needed, but for
> polygons, like coastlines, that already have a large number of vertices,
> I would not wish to add the same number of extra vertices to them, only
> to the long lines that really need them.
> In a polygon shapefile with varying types of polygons, what is the best
> way to approach this problem?
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191028/06b10bfb/attachment.html>
