[Qgis-user] Rasterize (2)
Alexandre Neto
senhor.neto at gmail.com
Wed Oct 30 02:15:43 PDT 2019
Can you please verify that there's no invalid geometries in your input data.
Can you explain what options you have chosen?
Alexandre Neto
PS: please reply to all otherwise others won't be able to see your answer s
A terça, 29/10/2019, 16:55, Carolina Rey <carredy at hotmail.com> escreveu:
> Yes, I tried it already with this tool. QGIS (Madeira and Noosa) crashes
> each time I try it with the polylline-shapefile…
> *Von:* Alexandre Neto <senhor.neto at gmail.com>
> *Gesendet:* Tuesday, October 29, 2019 5:42:19 PM
> *An:* Carolina Rey <carredy at hotmail.com>; QGIS User <
> qgis-user at lists.osgeo.org>
> *Betreff:* Re: [Qgis-user] Rasterize (2)
> Ah! What you are looking for is the TIN Interpolation tool.
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/interpolation.html#tin-interpolation
> Alexandre Neto
> QGIS Support
> www.qcooperative.net
> A terça, 29/10/2019, 16:18, Carolina Rey <carredy at hotmail.com> escreveu:
> Thank you for the answer. I will anyway not be able to use it because of
> missing information.
> I am also not sure if this tool is going to give me the result I need,
> which is the raster of a digital elevation model as a polyline. Is there a
> special tool for that? I only found an ArcGIS tutorial which uses its
> function "topo to raster" and I can't find a similar tool in QGIS.
> Thank you again (agian and again)
> Carolina
> *De:* Alexandre Neto <senhor.neto at gmail.com>
> *Enviado:* martes, 29 de octubre de 2019 15:50
> *Para:* Carolina Rey <carredy at hotmail.com>
> *Cc:* QGIS User <qgis-user at lists.osgeo.org>
> *Asunto:* Re: [Qgis-user] Rasterize (2)
> You can determine how the image resolution in two ways:
> 1. Using the extent and the size of the pixels (which will calculate the
> number of rows and columns necessary), commonly named pixel resolution.
> 2. Using the extent and dimensions in rows in columns (which will
> calculate the size of individual pixels)
> For option 1, you use the georeferenced units, and fill the next two
> options with the pixel resolution in the georeferences units, for example
> 10 x 10 m.
> For option 2, you choose "pixels" and fill the next two options with the
> number os columns and rows of your output raster.
> Maybe the documentation could be more clear.
> Hope this helps.
> Alexandre Neto
> QGIS Support
> On Tue, Oct 29, 2019 at 9:51 AM Carolina Rey <carredy at hotmail.com> wrote:
> Thanks for the email.
> Actually I red the documentation but I don’t know what you mean by „pixel
> resolution in map units“. There is only an Option to choose Pixel or
> georeferenced units. I tried both…
> *Gesendet:* Tuesday, October 29, 2019 10:42:46 AM
> The rasterize tool has two options.
> Either use the number of horizontal and vertical pixels, width and height
> or the pixel resolution in map units.
> I suppose you are using the first one, thinking you are using the last. It
> happened to me too.
> In any case, when in doubt, press the help button.. it will lead you to
> our lovely documentation:
> https://docs.qgis.org/3.4/en/docs/user_manual/processing_algs/gdal/vectorconversion.html#id4
> Alexandre Neto
> QGIS Support
> A terça, 29/10/2019, 08:41, Carolina Rey <carredy at hotmail.com> escreveu:
> Hello everyone,
> to my last E-Mail (about rasterizing).
> I actually don't know how to set the values "horizontal" and "vertical". I
> tried with 30, 100 and more and the pixels in the result are big and the
> image isn't continuous although it should be.
> Thanks
> Carolina
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Libre
> de virus. www.avg.com
> <#m_4750615173200925584_x_m_8923964790142958604_m_-7369460918424281164_x_m_-5598934232850814134_x_m_-8204356460689832334_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191030/71bf1591/attachment.html>
