[Qgis-user] Problems using QGIS 3.8 with the 3.4 Training Manual
Matthias Kuhn
matthias at opengis.ch
Thu Oct 31 01:15:25 PDT 2019
Hi Alexandre, Ken,
I would like to second this opinion and first thank you very much for
bringing this subject up.
If you are fine with it, please follow Alexandre Neto's approach and add
new issues (one per issue you encounter) here:
https://github.com/qgis/QGIS-Documentation/issues
There we can help you (figure out what's wrong) and update the
documentation for everyone else too.
Thanks again
Matthias
On 10/30/19 10:41 PM, Alexandre Neto wrote:
> Hi Ken,
> It can be any of the three problems, but, since you are following
> orders, let's assume that it's not your error.
> I would start guessing that the documentation may be outdated. And it
> may not be a question of 3.4 vs 3.8, but really outdated information
> even for 3.4.
> This being said, can I ask you to open qgis-documentation bug tickets,
> whenever you find problems in the documentation?
> Thanks,
> Alexandre Neto
> A quarta, 30/10/2019, 19:18, SIGéal <sigeal at sigeal.com
> <mailto:sigeal at sigeal.com>> escreveu:
> Hi,
> I remember having this problem if I typed the shapefile name
> directly in the textbox, without clicking on the Browse button to
> select a location for the file.
> Hope this helps,
> Christophe
> Le 30/10/2019 à 19:29, Jorge Gustavo Rocha a écrit :
>> Hi Ken,
>> Where are you storing the new layer? Maybe you are not selecting
>> a folder where you can write the new shapefile (that's why you
>> get the permission denied error). Can you confirm the location of
>> the new shapefile?
>> Regards,
>> Jorge Gustavo
>> Às 16:15 de 30/10/19, Ken McCall escreveu:
>>> After years of using ARCGIS, I’m using the training manual to
>>> become acquainted with QGIS. I’ve downloaded 3.8, and worked
>>> through the first 100 pages with no problem. While some of the
>>> 3.8 dialog boxes don’t look like the training manual I’ve been
>>> able to see the required buttons, drop downs, etc. But on
>>> others, I’ve hit some deadends.
>>> For example, on page 105 when it try to create a dynamic map
>>> canvas, in 5.2.1.5, when I go to the Item /Properties Panel/,
>>> there is no /Position and Size/ section showing.
>>> Another example: On p. 114 in ‘Creating a New Vector Dataset’,
>>> when I try to save the dataset, I get an error message:
>>> ‘Layer creation failed: Failed to create file
>>> created_shapefile.shp: Permission denied.
>>> In both examples, I’ve tried several times, following the
>>> instructions, only to get the same result.
>>> So, questions:
>>> Is 3.8 that different from 3.4?
>>> Am I running into bugs in the software or the documentation? (It
>>> could be user error, but I’m painstakingly following the
>>> instructions.)
>>> Should I scrap 3.8 and go with 3.4 instead?
>>> TIA,
>>> Ken McCall
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Logo <https://www.geomaster.pt>
>> *Geomaster*
>> *Jorge Gustavo Rocha* | Software Engineer
>> *e:*jgr at geomaster.pt <mailto:jgr at geomaster.pt> | *m:*+351 910 333 888
>> *g:*41.54094,-8.40490 | *v: *510 906 109
>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20191031/20211e32/attachment.html>
