[Qgis-user] 1 to many relationship does not allow to display the many
Janneke van Dijk
janneke.qgis at gmail.com
Thu Sep 19 08:13:05 PDT 2019
3.6, but will check when I have time later tonight and see if other
versions show the same issue. And will create a sample project with bug
report.
Thanks!
Janneke
On 19/09/2019 18:04, Alexandre Neto wrote:
> It sounds like a bug...
> Can you provide a data sample and project. Also, what QGIS version are
> you using?
> Alexandre Neto
> On Thu, Sep 19, 2019 at 3:57 PM Janneke van Dijk
> <janneke.qgis at gmail.com <mailto:janneke.qgis at gmail.com>> wrote:
> Hi Alexandre,
> Also thanks for the quick response!
> What I can do with the DB manager is:
>> select location_point.geom, asset_point.assetid,
>> location_point.fid
>> from asset_point cross join location_point on
>> asset_point.locationid =
>> location_point.fid
>> This should work, but why the CROSS JOIN? a simple join should be
>> enough.
> I first had a simple join, then saw an example of a cross join and
> tried that in the hope that that would make a difference.
>> this query yields 170 records, corresponding with the number
>> of records
>> in the assets table. When I load as a new layer, the result
>> is a table
>> with 170 records, but 100 filtered (the total number of
>> locations). I
>> chose assetid to be the unique id (which it is).
>> Is that expected behaviour? How else can I display all the
>> records in
>> the assets table (instead of only the 100 that are filtered
>> now)? I know
>> I can do it in Postgres but for my purpose now I don't want
>> to go there.
>> An alternative is to create a relation between the two tables,
>> the assets will show in the location feature form. You can even
>> add more assets to a certain location.
> I have a relationship, and the assets will show up in the form of
> the location when you click on the location (including locations
> with several). However, it doesn't allow me to label the location
> with information from the assets, or create symbology based on
> asset information.
> What puzzles me is that the query results in 170 records, I would
> have expected the geometry to be joined to each of the 170
> attribute records and then be displayed - so where does the filter
> with a 100 suddenly come from? (Is this a bug?)
> As a work around I think I could get xy coordinates of the
> location, then join them to the assets, export to csv and import
> again as a delimited text layer for display purposes.
> I was hoping someone could either explain why this result makes
> sense, or that I just made a mistake somewhere...any more thoughts?
> Thanks for sharing your thoughts!
> Janneke
>> Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190919/6ecbcea1/attachment.html>
