[Qgis-user] Georeferencing a map
Stephane Goldstein s.n.g at gmx.com
Fri Sep 20 23:56:38 PDT 2019
I have exported many times georeferenced TIFFs from QQIS to use in Avenza.
I do so by creating map in the QGIS layout tool and exporting it as a TIFF
file, usually at 300 DPI. The files can get quite large though.
I think Avenza can only render RGB Tiffs, so if you try to load a one band
or categorical raster you probably won't be able to see anything on the app.
On Sat, Sep 21, 2019 at 4:23 AM Amanda Mjolsness <amanda.lignin at gmail.com>
wrote:
> I am trying to make a map to use in Avenza, but it is not georeferenced. I
> have checked and double checked the CRS, it is WGS 84/Pseudo-Mercator, and
> I have tried NAD 83 BC Albers, to no avail. How do I georeference a map?
> Thanks
> Amanda
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190921/26190097/attachment.html>
