[Qgis-user] problem importing dwg to qgis
Luciano Campagnolo
luciano.campagnolo at gmail.com
Tue Sep 24 04:59:26 PDT 2019
Hi! Could you please be more specific?
For example: Text of the error message, Version of the dwg file (and if it
is a "real" dwg), Contents of the dwg (if there are linked or xreferenced
files)...
It is usually good practice to purge the files before importing them...
Also, you could try open it with Autodesk TrueView and save it as dxf.
Regards,
Luc
On Tue, Sep 24, 2019 at 8:40 AM Boaz Bar Ilan <boazprosie at gmail.com> wrote:
> hi
> usually I succeed doing it
> I got a dwg file which has been opened easily in dwg but failed to be
> imported to my qgis
> ( 3.4 )
> is there a solution ?
> thanks
> boaz
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190924/08709c16/attachment.html>
