[Qgis-user] Cannot install QField Sync plugin
Matthias Kuhn
matthias at opengis.ch
Wed Sep 25 05:21:19 PDT 2019
Hi René,
2.18 is end of life. For using QField, QGIS >= 3.4 is required.
Apart from that QGIS >= 3.4 is highly recommended for any use.
Have a look at https://qgis.org/en/site/ for currently supported versions.
Best regards
Matthias
On 25.09.19 10:27, Rene Meringdal Gule wrote:
> Hi Mathias,
> I am using QGIS 2.18-28 and Qfield Sync 1.0.0.
> Best regards
> René
> *Fra:* Qgis-user <qgis-user-bounces at lists.osgeo.org> på vegne av
> Matthias Kuhn <matthias at opengis.ch>
> *Sendt:* onsdag 25. september 2019 10:11
> *Til:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Emne:* Re: [Qgis-user] Cannot install QField Sync plugin
> Hi René,
> The qgis2compat plugin is no longer required. Which version of QGIS
> and the QFieldSync Plugin are you using?
> Best regards
> Matthias
> On 25.09.19 10:07, Rene Meringdal Gule wrote:
>> Hi,
>> I am trying to install the QField Sync plugin. However when I install
>> the pluging it gives me the message " cannot import name QtWidgets".
>> I tried to uninstall the QGIS2combat pluging and then install install
>> QField Sync, but then it says that I need to have the QGIS2Combat
>> plugin installed.
>> Could anyone help me with this please? Thank you!
>> Best regards,
>> Rene
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20190925/ad543a11/attachment.html>
