[Qgis-user] Geometry errors while polygonizing raster data
Atharva Raykar
raykar.ath at gmail.com
Fri Apr 10 23:57:16 PDT 2020
Correction: The version I am using is 3.4 LTS.
On Fri, Apr 10, 2020 at 9:23 PM Atharva Raykar <raykar.ath at gmail.com> wrote:
> Hello,
> I have been trying to convert this raster data using QGIS's Polygonize
> function: https://daac.ornl.gov/VEGETATION/guides/Decadal_LULC_India.html
> The converted geopackage is returning many geometries with negative areas.
> So much so that the data is highly inaccurate, and some categories are
> having negative areas with x^10 sq. meters in magnitude.
> The features basically resemble the ones I found in this stack overflow
> answer: https://gis.stackexchange.com/a/243707/161470 , where the holes
> are located outside the geometry and are larger than the geometry itself.
> How do I troubleshoot this? Is this a bug with QGIS?
> I'm using QGIS 3.14 LTS.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200411/551dd7d8/attachment.html>
