[Qgis-user] merge shapefiles into one
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Apr 12 15:09:13 PDT 2020
If you have too many shapefile for this to work, drag and drop in Saga. You can merge there. Over a few hundred files, this if the fastest way to do it. Saga will also add the file name to a new field.
Nicolas Cadieux
Ça va bien aller!
> Le 12 avr. 2020 à 15:11, Dave Marshall <43carnaby at gmail.com> a écrit :
> Mark,
> I recently upgraded to 3.12 and didn't do anything extra to the standard upgrade but I do have the option - see below:
> <image.png>
> Dave
>> On Sun, 12 Apr 2020 at 19:07, Mark Fogarty <mark at fogartyconsulting.com> wrote:
>> hi. i'm new to the list and qgis, apologies if this has been asked. we're
>> working with the us census tract files available from census.gov here:
>> https://www.census.gov/cgi-bin/geo/shapefiles/index.php?year=2019&layergroup
>> =Census+Tracts
>> they are published as 54 separate zip files, one per state. we would like to
>> combine them into a single dataset. i found a lot of pages on the web that
>> suggest using qgis for that purpose. they all start with
>> Click on the Vector menu, Data Management tools, Merge Shapefiles to
>> One...
>> i just installed qgis 3.12.1, but my vector / data management tools menu
>> doesn't have that option. has that tool been removed, or is there a plugin i
>> need to install or maybe a different version?
>> is that data already available in a combined format from somewhere, or is
>> there a better way to do this?
>> thanks
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200412/7b6a0909/attachment.html>
