[Qgis-user] LTR usage survey
Andreas Neumann
a.neumann at carto.net
Tue Apr 14 00:45:48 PDT 2020
Hi Anita,
Thanks for sharing these stats.
I also had a look at the question labeled "In an ideal world, how often
would you prefer to have new LTR versions?"
431 out of 1691 (25%) would like to have a longer time span than 1 year
for LT versions
If we filter this by organization size, this number increases (as
expected) with the size of the organization. In the category 11-100
users, the number increases to 29%, in the category >100 users, it is
already at 40% who would like to see a longer life time of the LT
version. Probably if we had another category with even larger
organizations, that value would go beyond 50% ;-)
It was also good to see that 103 out of 1691 respondents represented an
organization with >100 users. I expected a lower number in this category
and was quite surprised.
Greetings,
Andreas
Am 11.04.20 um 16:22 schrieb Anita Graser:
> Hi,
> Thanks to all respondents, we've collected over 1,600 responses to
> this questionnaire!
> Some interesting tidbits:
> 1) The LTR concept seems to be well accepted: 50% of respondents use
> 3.10 LTR, 38% use 3.12, and 16% use 3.4 LTR.
> 2) Most respondents install patch versions but 27% do so less often
> than every 6 months.
> 3) Most respondents install .0 releases but 17% wait until .3 or longer
> 4) 6% of respondents work in organizations with more than >100 users.
> It will be interesting to look at those responses separately.
> 5) 7% say that they still need 32bit installers
> You can find the raw survey responses here:
> https://drive.google.com/open?id=1lECEhusQcpDpb50MSMYP_5BDfEl4jXeV
> We'll publish further analyses in the following days and look forward
> to any insights you might be able to extract from these results.
> Regards,
> Anita
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200414/d079e95c/attachment.html>
