[Qgis-user] topology checker - Check if point features are covered by line features
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Apr 17 10:51:24 PDT 2020
Bug report has been made
#35831
On 2020-04-17 12:58 p.m., Nicolas Cadieux wrote:
> Hi,
> Small correction,
> If you extract the end nodes (vertices) of the line, you can use the
> following rule. End node layer must be covered by endpoints of line
> layer or node layer must be covered by line. I therefore assume the
> QGIS topology checker can work for endnode only and not for "middle
> node" of the line. This is should be reported as a bug I think.
> Nicolas
> On 2020-04-17 12:42 p.m., Nicolas Cadieux wrote:
>> Hi Marshal,
>> I looked at your data. The first problem is that none or your line
>> nodes intersect with a point. It looks close... but it's not close
>> enough. By using "snap geometry location", I was able to create a
>> new line that snaps to your point. (called Topologie snapped_line in
>> the file I will send you in private). A "Select by location" or a
>> "Join Attributes by location" confirms that the points now intersect
>> the Topologie snapped line layer. The Join Attributes by location
>> will permit you to find the problems as you can discard records that
>> do not intersect. This will give you what you want.
>> As for the topology Checker, it seems that a line cannot cover a
>> point or a point cannot cover a line even if point and line nodes
>> intersect (Can someone confirm this?). I can only assume that QGIS
>> works with the correct assumption that a point and a line does not
>> have a surface to cover and therefore, cannot cover anything. I
>> assume, based on your observations that ESRI does not follow that
>> assumption.
>> You can however create a 1 m buffer around your line (Topologie
>> Buffered_line in the file). Then, you can create the rule (polygon
>> must contain point). That rule will work in the topology Checker.
>> Cheers!
>> Nicolas
>> On 2020-04-13 10:25 a.m., Nicolas Cadieux wrote:
>>> Hi,
>>> I don’t have QGIS in front of me. I looked around on the the net
>>> and was surprised to see the «covered By » option for points and
>>> lines. Unless a line is snapped, or intersects a point exactly on a
>>> Line node, it’s just about impossible to calculate if a line «
>>> covers » a point. This is something easy to do with a polygon but
>>> not a line because of float point precision error. You could buffer
>>> the lines and see if that helps. You could create a 1m buffer on the
>>> line (or the point). Make sure both layers are in the same crs so
>>> that additional calculations don’t need to be done.
>>> You could at the « select by location » side. I would look at «
>>> snap with » or «intersects with »options.
>>> Nicolas Cadieux
>>> Ça va bien aller!
>>>> Le 13 avr. 2020 à 06:11, Marshal Mappers <marshalmappers at gmail.com>
>>>> a écrit :
>>>> Hello everyone,
>>>> I want to use the topology checker to check if point features are
>>>> covered by line features. For example are the bus stops covered by
>>>> the bus lines.
>>>> Therefore I use the topology checker with the following rule:
>>>> "points" must be covered by "lines". But I get the error for all
>>>> points that "point is not covered by segment".
>>>> I even get the error for points that I edited on the line with
>>>> snapping.
>>>> Here my questions:
>>>> 1. Is it possible to check if point features are covered by line
>>>> features? With topology checker? In general?
>>>> 2. What does the rule: "points" must be covered by "lines"check?
>>>> Under what cicumstances is a point feature covered by a line feature?
>>>> I tried this in QGIS Versions 2.18.26; 3.4.15; 3.10.2
>>>> My OS ist Windows 10
>>>> I tried with shapefiles and geopackage layers
>>>> The CBS of point and line layers are the same. Here I tried the
>>>> coordinate systems with epgs: 31468 (DHDN / 3---degree Gauss-Kruger
>>>> zone 4) and 25832 (ETRS89 / UTM zone 32N).
>>>> If anyone could explain or point me to the right direction, that
>>>> would be awesome.
>>>> Thank you!
>>>> Best regards
>>>> Marshal
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200417/9e076672/attachment.html>
