[Qgis-user] Dumb USGS geotiff questions
Morgan Fletcher morgan at hahaha.org
Sat Apr 18 14:43:03 PDT 2020
(Resending, with screenshots as google drive links, to cut down message
size.)
I am running 3.12.1-București on a mac, os-x 10.14.6. My knowledge of GIS
is rudimentary, I've learned what I need to, to satisfy my curiosity about
my region, using old maps.
I have downloaded all the USGS maps for my region - Oakland, CA, USA, which
corresponds to "CA Concord" - from USGS topoView, in geotiff format.
Opening them in QGIS gives fairly wild offsets; they are not all encoded
the same way, yet have common corners. Features on the map vary with what
modern maps show, but getting their corners right would help me a lot.
If I create a new project, set my CRS to WGS 84 / Pseudo-Mercator
(EPSG:3857) as I think is correct for my base map, Google Maps (EPSG:3857 -
WGS 84 / Pseudo-Mercator - Projected) then Layer > Add Layer > Add Raster
Layer > Raster Dataset > CA_Concord_465520_1943_62500_geo.tif > Add, I get
prompted with:
https://drive.google.com/file/d/1FKVPrHLtXXKK8a-QTTz3IigT9dpj1Hou/view?usp=sharing
I don't know what to choose, here. I chose the first one. I've tried
others. The tif.prj file does say
DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],
which I am guessing conforms to NAD27. If I add an opacity slider to the
new raster layer, set its opacity, and then use the Zoom to Coordinate
panel to navigate to 37º45'N 122º15'W, I find that the point is off from
what's on the map, see:
https://drive.google.com/file/d/10vYtcM1FZ-vdS3z1FPW2EYbrNy2sj65L/view?usp=sharing
This is similarly true at the top left:
https://drive.google.com/file/d/18naBKuwk6rZ9DP0tFOZxnGKlIpRQgDKM/view?usp=sharing
Also, note how the map shows two lines at top left, it's true at top right.
This is something to do with projection, I think. I've tried to
georeference these lines, to get them to line up right, but which
intersection do I use, when there are two vertical lines intersecting with
the top, horizontal border, to reference 122º 15' 38º 00' ? I've had mixed
results, trying to use deg-min-ss coordinates to georeference these; I get
a map off the west coast of Africa. Using points on the map is more
successful.
All the maps have slightly variant values in their tfw files. Their prj
files are more uniform, but also show variations. I'd like to normalize
them all, so that I can view the USGS topo maps for my region over time.
Advice?
Thanks,
Morgan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200418/27eded83/attachment.html>
